I've copied a project and renamed it in order to undertake a number of modifications, I've ensured that the dgn file is identified with the correct folder (the new one) however when running the Part L I get a string of "bad references: CONSTRUCTION & GLASS" - the files in the standards / catelog folders is a copy of the oringinal but it's not reading them nor is it reading the original position folders.
Any ideas out there ?
Hi Graham,
I am guessing the issue was the renaming of the WorkSet folder, as there are also two small config files that are required to tell the software where to find all your data. These get created when you create a new Workset. The article below should be of assistance with this
Opening a Received Project - OpenBuildings | AECOsim | Speedikon Wiki - OpenBuildings | AECOsim | Speedikon - Bentley Communities
Does that help at all?
Shane
Shane Regan | Principle Building Performance Support Engineer
Hi Shane
I've done that already. I've also copied and renamed the .dgnws and the .cfg files
Any other ideas
Cheers Graham
Hey Graham,
Could you please review if you are opening the design model under the parent workset-workspace? By meaning parent workset I am directing to the workset under which you have created the dgn model.
Let me know.
Krishnendu
Hi Krishnendu
I've tried it again and it's still not working - I've checked the folders / worksets / workspaces / etc and as far as I can see it's all correct. I've copied projects previously and renamed them and never had an issue but for some reason this isn't working. As far as I can see I've followed all the guidance.
Yes that's fine Krishnendu
