I've copied a project and renamed it in order to undertake a number of modifications, I've ensured that the dgn file is identified with the correct folder (the new one) however when running the Part L I get a string of "bad references: CONSTRUCTION & GLASS" - the files in the standards / catelog folders is a copy of the oringinal but it's not reading them nor is it reading the original position folders.
Any ideas out there ?
Hey Graham,
No worries,
I will be scheduling a call with you shortly to investigate the problem. Does that sound fine?
Krishnendu
