Hi, I have an urgent query i would like to know if it is possible to apply solar panel on a building and run energy analysis on OpenBuilding energy simulator or any other software of Bentley your response will be much appreciated
Hello Ibrahim,
What outputs are you intending to obtain in this regard? I ask as Solar Panels would have no bearing on the standard calculations eg such as heat gain / heat loss. They are however available in Part L as below:
Shane Regan | Principle Building Performance Support Engineer
