install obd update 10 on windows 11
Hi everyone
I don't know if its my windows installation, because when installing the software I reach the point to select a drive for installation or to select the network installation I get a window with only the desktop location
Is there a workaround for this issue?
James
Parents Reply
  • Hi James,
    That would most likely be due to your Windows permissions, preventing the software seeing the other locations. You would need your IT to ensure you have full permissions, or you could test by running the install/update as Full admin and see if it persists. Entering the path directly should be perfectly fine to do in the meantime as a workaround.
    Shane
    Shane Regan | Principle Building Performance Support Engineer
