Hi everyone
I don't know if its my windows installation, because when installing the software I reach the point to select a drive for installation or to select the network installation I get a window with only the desktop location
Is there a workaround for this issue?
James
Hi James,
That would most likely be due to your Windows permissions, preventing the software seeing the other locations. You would need your IT to ensure you have full permissions, or you could test by running the install/update as Full admin and see if it persists. Entering the path directly should be perfectly fine to do in the meantime as a workaround.
Regards,Shane
Shane Regan | Principle Building Performance Support Engineer
Hi folks
I managed to get true by reinstalling Windos and than install OBD 1update 10
Many thanks
Great to hear, thanks for letting us know.
Shane
