I have created different Project folders under my own Worksets. but after i run the 'Project A' calculation, I found that the XML files as well as all the associated reports were saved at the 'Output Folder>Results' of 'Project B'. Can i change the path? Thanks
Hi Brian,
Can you please share some screengrabs of the output files?
Also, please do let us know which version of OpenBuildings Designer you are using?
Regards,Sayan Acharyya
Hi Sayan,
I am using OpenBuildings Designer Connect Edition Update 10 Version 10.10.00.199.
I run the calculation of Project- 2370-25 and the output file didnt appear in this project folder (refer Figure A). On the other hand, after i searched around, the files are saved at the other folder (Figure B). kindly tell if more screenshoot could help or the its not clear.
Figure A
Figure B
Brian
Hello Brian.
Can you please go to Configuration Variable dialog & search for _USTN_OUT, ES_DIR_RESULTS, ES_DIR_RESULTS_STEADYSTATE and let me know the locations where it is pointing.
Ideally _USTN_OUT should be pointing towards your Workset\Output and the other configuration variable should point with _USTN_OUT.
Regards,Alifur
Answer Verified By: Shane Regan
Hi Alifur,
Here you go. It seems all theses are pointed towards a subfolder in EQ_QUICKSTART rather than the output folder in each individual project. Can i Set it as i wish.? Thanks
Hello Brian,
Yes you can definitely do so, but this needs to be configured properly. Please add this configuration variable in your workset.cfg file._USTN_DISPLAYALLCFGVARS = 1
After that Open ES and then search for _USTN_WORKSETROOT and check where it is pointing towards.
