I have created different Project folders under my own Worksets. but after i run the 'Project A' calculation, I found that the XML files as well as all the associated reports were saved at the 'Output Folder>Results' of 'Project B'. Can i change the path? Thanks
Hello Brian,
Yes, but as you are not able to see the configuration variable in configuration variables dialog hence you have to make the change in 2370-25*.cfg file.
Regards,Alifur
Hi Alifur,
Oh i get it. i am wrong to opening 'Configuration Variable dialog' while loading the 2370-25*.dgn file. the output are now saved to the project output folder now. thanks a lot.
However I just checked the .cfg files of another training and the output is also directed to ES_Quickstart (refer to the below). I wonder should i amend it eveyrtime i start a new project. and is it because i start a new project which use ES_quickstart as the template.
Brian
Yes, try uncomment that line as _ustn_out is already defined in the workset_xx.cfg files. No need to define the same variable twice.
