I have created different Project folders under my own Worksets. but after i run the 'Project A' calculation, I found that the XML files as well as all the associated reports were saved at the 'Output Folder>Results' of 'Project B'. Can i change the path? Thanks
Hi Alifur,
Is it like this? I cannot find any file name call 'workset.cfg' in my computer.
Brian
Hello Brian,
Put 1 in the new value.
Regards,Alifur
hi
It points toward my project folder now @2370-25'. but i just checked that _USTN_OUT, ES_DIR_RESULTS, ES_DIR_RESULTS_STEADYSTATE are still pointing to another project folder 'ES-QUICKSTART'.
Please open you @2370-25*.cfg file & check the _USTN_OUT variable. _USTN_OUT = $(_USTN_WORKSETROOT)Output/
It should be pointing like this.
If you are still unable to get to understand, then please raise an SR, we would need to conduct a meeting.
hi Alifur,
is it mean i should change the New value to $(_USTN_WORKSETROOT)Output/
as it it still pointing to output folder in ES-Quickstart.
