Question: I know how to turn off (hide) roofs however how do you turn them back on ?
Hi Graham, hope you're well. You should be able to just right click on the roof in the project tree as below and then Show Roof - is this not displaying for you?
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Answer Verified By: Shane Regan
Thanks Shane, obviously something amiss with my setup - this message is VERY hit and miss on my system, the majority of the time I only get "Hide Roof". Also even with all roofs turned on I still don't get anything showing in the 3D view
Hi Graham,
I've been testing this here at length but haven't been able to reproduce this at all. Might be worth checking that it is not related to your display settings:
Display issues with menus - OpenBuildings | AECOsim | Speedikon Wiki - OpenBuildings | AECOsim | Speedikon - Bentley Communities
If no joy I'd be happy to take a look at one of the projects with these issues? If you'd like to send one over I can log a Service Request and forward you an upload link?
Hi Shane
Ok, I think I’ve narrowed this problem down to when the problem occurs - after I’ve set-up a roof to the underside of the false ceiling I’m unable to turn the roof back on. It's also a different project from the one I reported above.
Been testing this here but still working for me!
I'll log a Service Request now to get that project off you and will take a look. You should get an email shortly.
