Question: I know how to turn off (hide) roofs however how do you turn them back on ?
Hi Graham,
Thanks for bearing with me on this one. From what I can see I think you may just have missed the final step with the roof - it looks like the surfaces are not showing as the roof may not have been Setup over the rooms below?I ran through the Setup via the following:The roof surfaces then appear in the model:
Hopefully that's it, let me know how you get on.
Shane Regan | Principle Building Performance Support Engineer
Hi Shane
The procedure I use is to "setup" when I'm in the design function of the roof menu NOT going to the setup direct as use've done - could this be the issue ?
Cheers Graham
Thanks Graham,So via the option below? This should be perfect, as goes to the exact same Setup menu. If you try that way on the project now does it resolve the issue?
