I saved a copy of complete folder of my worksets to the company server as backup after i finished a scenario running.
however, i found that some settings including the project material, E&M systems are lost when i draw back to rerun for checking. model setup is still there but other previous input information are all lost
can you advise the path and file name where these information are saved and i could get them back.
Brian
Hi Brian,
You will have associated the model to a new WorkSet, which does not contain the same construction data as your original WorkSet. To open the project I would instead recommend doing as follows:
Opening a Received Project - OpenBuildings | AECOsim | Speedikon Wiki - OpenBuildings | AECOsim | Speedikon - Bentley Communities
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Answer Verified By: Shane Regan
Alternatively, you can copy the data over by copying the XML files outlined here.
Thanks Shane, the problem is resolved.
