hi,
I have tried all the ways but it is still not feasible to define the ventilation system to ID-D : 'Zonal balanced supply and extract ventilation system' under Scottish Building Regulation 2022. Could you some hints.
Brian
Hi Brian,
There will be a lot more going on behind the scenes in relation to this in the SBEM calc methods, as it incorporates data like room types and building types to calculate a lot of such outputs, by using the data on the NCM database (eg the effect of this on occupancy is detailed here, for instance). The geometry of the room will also impact on this, should it be top-lit or side-lit. Please find some further details of what I mean from the iSBEM user guide below, to give you an idea:The NCM modelling guide also outlines what other aspects can impact on these results, eg:
Should you wish to dig further into the calc methods the NCM modelling guide and iSBEM user guides are available freely on the NCM website as shown here, they contain a lot of useful information that should assist.
Shane Regan | Principle Building Performance Support Engineer
thank you so much Shane
You're very welcome Brian!
Shane
