Hi
When inserting the design data for heating and cooling loads via a full fresh air ventilation system is there a method for allowing for the energy recovered from a thermal wheel heat exchanger to reduce the required loads?
Hi,Not sure if you have seen the following article, but it may assist you with choosing the most appropriate design:
CIBSE Gain Design Conditions and Fresh Air - OpenBuildings | AECOsim | Speedikon Wiki - OpenBuildings | AECOsim | Speedikon - Bentley Communities
The four systems are pretty pre-determined so if you wanted to model more specific systems with additional custom components like heat recovery, you may need to consider instead using Simulation (ie you can see the Heat Gains and Losses simulation alongside overheating here) , where you can incorporate a custom HVAC System, eg as below:
Hope that helps!
Shane Regan | Principle Building Performance Support Engineer
Answer Verified By: Shane Regan
