When accessing the project tree on one of our projects the software shuts itself down with no error codes given please help.
thanks in advance
Hi Sayan thanks for your response.
unfortunately this hasn't seemed to have work and the program still crashes with not error codes.
Have you got any other ideas?
Hi Grant,
Thanks for your response.
Is the crash happening with one project or any other projects as well?
Also, can you please let me know the version of OpenBuildings Designer you are using?
Regards,Sayan Acharyya
Hi Sayan,
it does only seem to be with this project so far. and please see my version of the software below
Thanks for the update. So, it looks like there's something going on with that particular project and we need to look into it thoroughly.
Can you please provide me your email id and I'll create a new case on your behalf?
Sure thing
can you please email it to morgan.portat@accent.ac as this is his project
thanks
I'll use this email id to create a new case in our Service Now support portal and then I will ask the user to provide me the project to investigate further.
I tried to raise a new case using the email id above but no record can be found.
Can you please ask any of your colleagues to raise a new case and I'll look into it accordingly?
