Uncontrolled heat gains
I am using Hevacomp V8i to model a residential development. The issue that I am having is with the heat gains. I have modeled the rooms assuming that they will be cooled in the summer to a certain temperature - which you can simply input this temperature. Is there a way to model the rooms to see the effect if there is no cooling in place. Does anyone have any experience on doing this?
Thanks in advance
Sarah
