HVAC manager wont display?
AECOSim v08.11.09.33.
Zone system manager and other component properties display OK, but HVAC system manger does not pop up.
Any ideas?
Cheers
Phill
  • Phill - Apologies for the delay in responding to this query - we had a little difficulty figuring out the cause of the issue before we could find a resolution..
    It appears that the issue is caused by removing all of the HVAC systems from the project using the HVAC Manager. Once this is done, applied and ok'd, the HVAC Manager will not re-open again.
    There are two resolutions to this - the first is likely the easiest method, but I have included the second for completeness sake.
    Option 1
    • Create a new project in AES
    • Using Windows Explorer, go to the new project folder and then into the Hvac folder. there should be 3 files in here:
      UserHvac - Steadystate heat gain and loss.XML
      UserHvacHeader.xml
      UserHvacindex.xml
    • Copy these files into the corresponding HVAC folder in your existing project folder
    • You should now be able to open the existing project and access the HVAC manager.
    Option 2
    • Assuming you have accepted default installation folders, Using Windows Explorer browse to:
      C:\ProgramData\Bentley\AECOsimEnergySimulator V8i\WorkSpace\System\energydata\HVAC\
    • Locate the Hvac-Steadstate heat gain and loss.xml file and copy it into the HVAC folder in your project directory
    • Rename the file by inserting "user" at the beginning so it becomes UserHvac - Steadystate heat gain and loss.XML
    Duncan Brown
