Can't Delete Room References
I'm new to using Hevacomp and am struggling to work out how to delete the room references that I have created but no longer need.
I've been mapping out a new residential building, and had to copy some floors over in order to change the levels of the floors. This created new room references increasing the total number of rooms to 1,000 which appears to be the limit of the software.
I have since deleted some of the floors which I no longer need, which should also have deleted the room references, but instead they are still there and the total room count is still on 1,000 rooms. Is there any way I can go in and directly delete the room references and reduce the number of rooms that have been created on the file?
Parents Reply
  • The limit of 1000 rooms was removed in the latest version of the software (Hevacomp v26), so my first suggestion would be to install this version, as detailed here.
    If you wish to continue in v25 then we may be able to delete the data behind the room references, however we would need a copy of your project to do so. If you need to send the project, please exit Hevacomp, zip the project folder and either attach it to this forum thread, or upload privately as described here.
    Shane Regan | Principle Building Performance Support Engineer
