Pitched Roof, External Walls
Hi there,
I have attached a pitched roof to my building and selected the option in the 'Set up roofs' tab, to 'Extend walls to underside of roof and correct room volumes.
The majority of the entire building has adjusted the walls to this setting, but there are a few external walls that are not adjusting and are going straight up through the roof.
Is there something that you would suggest doing? (I have tried retracing the rooms).
Kieran
