Hi there,I am currently using Hevacomp, but it keeps coming up with these two errors;Meteonorm weather file are not available&Run-time error '9':Subscript out of rangeCan anyone help?Regards,Michael
Hi MichaelA quick follow up to my colleagues response above. Once you have set up the correct permissions to the software, you may need to reset your project's weather location so the project can function correctly.
Load up your project.From within Design Database select the Building Data option.Select a weather location that is different to the one you require
Click the tick to exit Building Data. Now go back into Building Data and select the actual weather location you require.Click the tick to exist Building Data.This will have reset the weather data for your project.
Duncan Brown
