Hi there,
I have inputted all of my emitters and pipes onto the ground floor but just realised I've inputted the wrong floor level height.
Is there an easy way to change the project information for that floor?
Or is my easiest option to copy the pipework and emitters to another floor that I have not created yet delete the original ground floor and then insert a new DXF file of the ground floor at the right height?
Kieran
Hi Kieran,
Yes, the workflow you describe is the best way to do this in Netsys. There was actually another forum post in relation to much the same topic quite recently, which you may find helpful - please see here.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Answer Verified By: Shane Regan
