Hi there,
I am naturally ventilating an old refurbished building that is very leaky, how would I increase the air changes per hour rate without it affecting fan power?
Kieran
Duncan Brown
Keiran - If you are running the calculation indicated in the image below, then fan power is irrelevant, and You can set air change rates in room data.
