<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Design Database - AutoCAD popup</title><link>https://communities.bentley.com/products/building/performance/f/hevacomp-forum/111662/design-database---autocad-popup</link><description>Hi there,
 Whenever I open Hevacomp design database the autocad 2015 window pops up and says the program is configuring but it just hangs at the same percentage, is there any workaround for this?</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Design Database - AutoCAD popup</title><link>https://communities.bentley.com/thread/340488?ContentTypeID=1</link><pubDate>Mon, 28 Sep 2015 15:44:29 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:64c5d598-c697-40df-8d3a-88045d28f3f9</guid><dc:creator>Shane Regan</dc:creator><description>&lt;p&gt;&lt;span style="font-size:inherit;"&gt;Hi Anne,&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span style="font-size:inherit;"&gt;We&amp;#39;ve had quite a few users get I touch about this matter, however it is actually caused by a known issue with Autocad rather than Hevacomp. It seems&amp;nbsp;it associates itself with other, unrelated, software. Further info can be found &lt;a href="http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016/autocad-2015-installer-launches-when-starting-other-unrelated/td-p/5311359"&gt;here.&lt;/a&gt; There is also an example of a&amp;nbsp;similar Autocad&amp;nbsp;issue with Word discussed &lt;a href="http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016/autocad-2015-installer-tries-to-run-when-i-start-microsoft-word/td-p/5100352"&gt;here.&lt;/a&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;Should you have any problems then I would suggest contacting Autodesk or your IT and they should be able to resolve this for you.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
