I have a building where there have been changes to the main core areas on each floor. I have edited the DXF files to reflect the changes but when I open Hevacomp Simulator the old floor layouts are still present. Is there a simple way to get the new layouts to appear so that I can delete the old rooms and add the new ones?
Kind Regards
Clive
Hi Clive,
I suspect that your DXF background is not updating to your new layout due to the cache files within the project folder. If your new DXFs have the same name as the old ones then the cache files will be used.
To display the new DXF, simply rename it and then go to CAD Input > Defaults > Default Data and select the new DXF, as below.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Answer Verified By: Stephen Brown
