I am putting together a model of a podium section of a building.
the first floor is raised so that a car park can be placed there and on top of the first floor is the second.
How can i arrange the model to show the air gap underneath as it affects the heat loss considerably .
Chris
You should set up a 'Ground floor' in Fabric to represent your construction, and use this in your model. Note, however, that the Ground Floor part of the Fabric program doesn't calculate the U value for the surface, so you should use the Mat program to calculate the U value then edit your new Ground Floor to reflect this.One further note - it has come to our attention that there is an issue with the Mat program in the current release that could generate an Run Time Error 53 or a Run Time Error 380 when constructing your surface. If this happens then please consult this document for a resolution.
Duncan Brown
