<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Lodging an EPC certificate</title><link>https://communities.bentley.com/products/building/performance/f/hevacomp-forum/114136/lodging-an-epc-certificate</link><description>Where do I find the right file for lodging an EPC certificate? I have been told that this is an XML file.</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Lodging an EPC certificate</title><link>https://communities.bentley.com/thread/349420?ContentTypeID=1</link><pubDate>Wed, 09 Dec 2015 10:14:49 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:f432eac8-8b8e-49c8-8202-f27c136bb01d</guid><dc:creator>Duncan Brown</dc:creator><description>Stuart - That&amp;#39;s correct. Assuming you have entered your credentials correctly into the program, and have run your calculation, an XML file should be generated within your project folder. If you have run the calculation previously, you may find more than one XML file, so be sure to select the one with the correct data and time stamp.&lt;br /&gt;
&lt;br /&gt;
Regards&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
