We are having problem with the hevacomp software. There are no pipe sizes greater than 500mm in the software database. This is a problem as we have pipes installed within the systems we are trying to model which are 600mm and above. Can you please provide an updated database so that we can produce an accurate model?
Duncan Brown
Thomas Can you try the following?
this will allow you to fix pipes up to 700mm
Answer Verified By: Duncan Brown
