I have some weather data files which I want to use to load some calculations and simulate some situations. The extensions of those files are .ddy, .epw, .stat and .wea. Does anyone know how can I use any of those files in order to load that data in to Hevacomp???
Joaquin Figueroa
Joaquin - the data you have is not compatible with Bentley Hevacomp. If you wish to use weather data other than the Meteonorm data then you will need the CIBSE current weather set (see here - despite what this page says, Hevacomp software cannot use the EPW data). Once you have obtained that data you can follow the information here to install it and use it.regards,
Duncan Brown
Answer Verified By: Joaquin Figueroa
