I would like to know why I cannot find any effect of shading on a wall gains that does not have windows. When I do the Cibse Gain calcs., the results are the same! (if the wall has windows, the results are different with or without shading).
Jose
Hi Jose,
Are you referring to the tick-box as below?
If so then please note that you must define the external buildings in the Shadows function in Design Database - have you done so? Please see extract from the Hevacomp manual below (press F1 in Hevacomp to access this).
If you opt to include external shading, the calculation will check if each window is shaded by external obstructions at each hour of the day. Shaded windows will receive diffuse solar radiation only. Use the Shadows module to set up external buildings.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Answer Verified By: Stephen Brown
