Hi! I'm starting to work with the HWS, and cannot find a way to connect the Return pipes. I'm trying to connect those pipes after (or before) each set of hot water appliances, but I receive a message saying that is a "spurious connection". Do I need another System Marker for the return pipes? and when I came but to the flow source, where do I connect them?
Thanks in advance!
Jose
Jose - I would recommend examining this document. There is a downloadable HWS project linked from in there and this demonstrates a number of different methods of connecting projects together.Regards,Duncan
Duncan Brown
Answer Verified By: Duncan Brown
