when setting up various floors for a building and you are asked to enter the elevation i am having an issue aligning the floors.
for example setting the grade on the ground floor top 35.0m then the 1st floor to 42.0m would suggest a wall height of 7.0m however, when i go to the global; setting and set the wall height to 7.0m it overlaps with the 1st floor. Is there a hidden false ceiling i am not accounting for?
Steve Brown | Bentley Systems
