Simulate the cooling needed in the morning through Cibse Gain, after having turned off the plant operation
I am using Cibse Gain to simulate the cooling loads in a office building. After the weekend or in each morning, I would like to know the cooling (or heating) needed (pulldown load). The only way that I´ve seen to do it is, in the "Building Data" screen, set the "Cooling Plant Operation" hours, for example being ON from 6:00 to 18:00 (I don't know if I can use the Plant Profiles, I haven't seen where). When I calculate the loads using Cibse Gain, there's no values between 18:00 and 6:00 in the morning, but those are precisely the values I want to get when the plant is turned off.
Thanks in advance for the help.
Jose
