How can I model a wall occupied completely by a window, with direct radiation but that wall is adjacent to a conditioned space (it is not an exposed wall) whose walls are glass, so I have glass then a conditioned room and then another glass.
Duncan Brown
Hi Duncan ... sure it was not well explained. Can you see the jpg inserted? I am interested in the blue room. What I want to simulate is a not exposed window which is adjacent to a conditioned room whose longest external wall is in fact a window. So I want to take into account the radiation but no conduction as the internal window is adjacent to a conditioned space. I hope now is clearer.
Hi José,
Thanks for the info, it looks like you need model glazed surfaces on an internal partitions. It is possible to accomplish this in Hevacomp, however you would need to use Simulator to do so. The steady state Design Database calculations cannot take internal glazing into account in this manner.
If you wish to use Simulator, then to model this you would need to use the 'Atrium Partition keywords', as described in the Simulator > Design Data section of the manual, eg:
Glazing and opening
> Full height glazing /AtriumGlass 5/
This creates a full height internal glazed panel from floor to ceiling between the adjacent room and the atrium space. The required glazing type (5 in the example) is specified, from the table of glazing.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
