Heat gain due to LED Lighting
The default % convection figure for lighting heat gain is 70% and I believe this would be appropriate for unvented recessed fluorescent fittings.  What would be the appropriate figure to use for LED lighting, would 100% be right?
  • Roy - While it is outside of our aegis to provide engineering advice, our research would suggests that 100% would be a reasonable figure. However, you should note that the final decision is entirely down to yourself.
    Duncan Brown
  • Thanks Duncan
    Roy Dowling
    CEng, MCIBSE, BSc(hons)
    R Dowling Consulting Engineers
    Tel: 07876 397846
    CONFIDENTIALITY NOTICE: This email message and accompanying data are for the sole use of the intended recipient(s) and may contain information that is confidential. If you are not the intended recipient, you are notified that any use, dissemination, distribution or copying of this message or data is prohibited. If you received this email message in error, please notify us immediately and erase all copies of this message and attachments.
