Does HEVACOMP have the facility to tell you the temperature rise in a technical room such as a switch gear or instrument room once all HVAC fails?
Additionally the time taken to reach this state of thermal equilibrium.
So if the HVAC system was keeping the room between 15oC -25oC, you could assume the temperature is 25oC (heat load from equipment, infiltration, fenestration etc) and all of the HVAC fails (including redundancy). The rise and rate or rise in temperature would depend on several factors (which walls are open to atmosphere, U values etc).
Can HEVACOMP calculate this?
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
