Netsys Heating Connecting Pipe Header Problems
When trying to add a pipe header into a Netsys project, firstly I can't seem to edit the length/size only the rotation and secondly once the header has been positioned and supposedly connected to the emitters and a system marker, it comes up with an error saying no flow in current system.
I have connected the emitter to low level pipework and the isometric view confirms this, the pipework from the system marker again appears to be fine but there is no header shown in isometric (and it turns grey on the 2D plan) and obviously is leading to a break in the pipes, but there appears to be no way to connect the header.
Any help would be great.
  • Graham - You cannot adjust the width and height. I'm not sure why they are offered as an option, but there is no way to edit them. With regards drawing pipes into the header, the best method is to place the header, attach your incoming pipe to the centre.  When drawing the outgoing pipes, start at the header. It may help to zoom in a little. You should try and draw from close to the centre of the header. If your pipe connects correctly the start point will be highlighted with a green circle. a light green circle indicates snapping to another pipe rather then the header and a black circle indicates no connection.
    (Note: This information is also referenced in the Netsys general FAQ)
    Duncan Brown
    Answer Verified By: Duncan Brown
Reply
    Duncan Brown
