Hi
I'm looking for a way to print off the max Zs result for each circuit so this can be handed to the person carrying out the testing. For BS/EN 60898 devices it's easy enough to look up values in standard regs book or tables, but when it comes to larger HRC/BS88 devices or more complex 60497 MCCBs especially with time delays and variable settings this becomes more critical.
I have looked in the "Report Designer" option but this information isn't available. Similarly I have looked in the NICEIC Schedule of Test Results report which does have a column for the result, BUT after page 1 the BS/EN number goes missing along with the type (B,C,D) and also the Max Zs value is wildly different from BS7671 for standard 60898 devices. I am aware the Connect calculates the overall circuit impedance and then uses formulas to ensure that disconnection takes place in the required time which may present variations between the standard BS7671 information and what Connect uses, but I would expect the resulting maximum values to be similar.
I can't believe I'm the first person to need this so I suspect I'm simply looking in the wrong place.
Thanks in advance for any help offered.
Derek
Duncan Brown
