Hello
Is there any way of showing a breakdown of the heat gain loads on the CIBSE Gain calc like solar load and casual load etc?
I know its always appeared in the past.
Matthew
Matthew, you have probably turned on Temperature Rise in the Design Data tab. When you use Temperature Rise the individual loads are combined in the underlying equations and cannot be accurately split out afterwards.
Steve Brown | Bentley Systems
Answer Verified By: Matthew Galletly
