Netsys HWS Pipework Errors and Notes
Hi there,
I am struggling to find the faults with my HWS Netsys model. I keep getting different errors all over the system and some don't even make sense.
One that keeps occurring on the same spot is 'spurious connection found', even though I delete all pipes associated with it and re-draw it.
A few of other things are:
Some of the pipe sizes notes on the drawings won't delete
Some of the pipes that I have deleted and don't show up in the isometric view are in fact still there, since when you single click a pipe you are drawing onto the invisable pipe run the NEW pipe I am drawing stops. (Asif to say it is connected to the pipe which is already there)
Also, I have inputted the minimum pipe diameter from the system marker as 15mm, but some of the main branches from the boiler are coming off at 10 or 8mm.
Please would someone be able to have a look at the system for me?
Kind regards,
Kieran Lines
  • Keiran
    First of all, please consult this document regarding debugging Spurious Connections. These are usually caused by connecting return pipes into flow sections that are not connected to the main flow system.
    With regards your pipes showing up as 8mm and 10mm, this again suggests you have a disconnected flow system that was previously connected and sized, but is no longer connected. The methods described in the Spurious Connection document can help here. Examine the pipe numbers for those sections, and then examine the rest of the schematic for duplicate pipe section numbers. If you locate them, then that indicates the 8 and 10mm pipes are not connected. If you can size your system, again look for the section numbers in your results and see if they are showing up as 8 and 10mm. If not, again, this indicates disconnected sections.
    You can use the Isometric view to check your system, too. If sections do not change colour after checking the system that's a strong indication they are not connected.
    Please try these methods first and let me know how you get on.
    Duncan Brown
    Answer Verified By: Duncan Brown
Reply
  • Keiran
    Duncan Brown
