Hi Guys,
I have been asked to provide 2010 and 2013 SBEMs for a BREEAM 2011 project. I had originally built the model on version 26 (quite a large project) is there anyway that I can run the SBEM on 2010 regs on version 26? It won't allow me to run the project on version 25.
Kind Regards,
Andrew.
Andrew
I'm afraid there's no way to take a V26 project back into V25, and no way to run a 2010 calculation in V26. This document explains this.While this is of no use in this instance, if you have future projects that require the same treatment, you should design them in V25, which then can be brought forward into V26.Regards,
Duncan Brown
Answer Verified By: Andrew Campbell
