Hi
When doing the heat loss calculation, the results tab shows a blank page. The pie chart is visible though.
Can you assist? I believe it must be something related with Window 10...
Thanks in advance
Hi Luis,
This usually means that Crystal Reports (i.e. the program that runs in the backround to take care of Hevacomp reports) is not working properly and needs to be reinstalled. Please find details on how to do so here.
Shane Regan | Principle Building Performance Support Engineer
Answer Verified By: Shane Regan
Hi Shane, i'm having the same problem but the link to download crystal reports is dead, any ideas?
Hi Kevin,
Thanks for letting me know, I will update the link for you shortly. I will let you know when complete.
Hi Kevin, please try the link again, it should work for you now.
