Hi
I've finished the emitters placing and pipework arrangement in both floors with floor connector. Isometric view shows a correct layout.
After placing the system marker to the start of the network, clicking "size system" comes with a message saying "closed loop found in the system".
Can you help?
Luis
Duncan Brown
Luis - This indicates that there is a double pipe in your rise (drawn twice, or overlapping) that is connecting at both ends to another pipe section. The first steps to resolving this would be as follows:
Let me know how you get on with this?Regards,
Hi Duncan,
Followed your instructions. System seems ok on isometric view but now reporting "No flow in pipe on floor 1" and pointing to the floor connector position.
Let me know your thoughts
