<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Floor Change Connector</title><link>https://communities.bentley.com/products/building/performance/f/hevacomp-forum/128966/floor-change-connector</link><description>Hi,
 I am currently in the process of building a CWS pipe sizing model. I completed the top floor and copied the rest of the floors (6 Storey Build). After copying each floor as they are exactly the same I have added a floor change connector in order</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Floor Change Connector</title><link>https://communities.bentley.com/thread/393382?ContentTypeID=1</link><pubDate>Mon, 28 Nov 2016 15:34:33 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:8693676e-b790-4335-8d3d-2a68afa81155</guid><dc:creator>Duncan Brown</dc:creator><description>&lt;p&gt;Hey Josh - The program treats copied floors and individually drawn floors in exactly the same way.&lt;/p&gt;
&lt;p&gt;My recommendation at this time would be redraw your floor change connectors using the methods &lt;a title="Floor Change Connectors" href="/products/building/performance/w/building_performance__wiki/5092.how-do-i-add-floor-change-connectors" target="_blank"&gt;described here&lt;/a&gt;. While in some cases it can be preferable to draw in the whole riser then connect the floor piping appropriately, I would recommend connecting 2 floors together first so you can get the hang of drawing them in.&lt;/p&gt;
&lt;p&gt;Regards,&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
