When I add a roof generally, the walls are usually have a light brown colour. However, I am adding a roof to a 2 storey building. Part of the walls a light brown and the other parts a dark brown. Why has this occurred?
Duncan Brown
Tom - Thanks for the image you sent to my PM. Its hard to see what's going on from a flat profile image. Can you get the project to me using this link?
Apologies, Tom - I left out an important instruction! Can you make sure you exit the software, then zip up the project folder. Once done, you can upload the zip file to this link?
Thanks!
Tom - Ultimately there is nothing to worry about, apart from a discolored section of the 3D view. When the 3D view is rendered, we generate a number of triangular poly-vectors for each surface - this allows us to break out windows, etc, and also to draw complicated roofs - part of this routine isn't working correctly due to the complexity of the vectors at that section. If you consider the overhang (1) over the floor below, the position of the windows, the complicated roof (2, and inset 2) above where the windows are, the software is having trouble rendering the image.
The surfaces are being treated correctly in the calculation - this is solely a minor issue with the 3D renderingRegards,
