Deleting Roof Sections - Vertical sections
When there are multiple roofs for a project there is sometimes the need to delete a roof section.
This is relatively easy, just click on the section and delete.
However, it gets tricky when there are vertical sections of roof that need to be deleted. These cannot be easily selected like the normal roof sections.
You can click delete section and then use the arrow keys in the window to go through all the sections of roof until you get to the correct one!
I understand that there is a quicker way, could you please tell me how to select a certain vertical section of roof without having to use the arrow buttons?
