Dear Sir / Madam,
I am trying to perform an SBEM through PartL, although, the results and compliance report are not generating when I select all of the zones / all of the rooms.
However, when I select an individual room, the result and compliance report generate.
Could you please advise on this problem and if it is possible to attain a full set of results to perform an SBEM for the full building?
Kind Regards
Shane Regan | Principle Building Performance Support Engineer
Hi Jamie,
I thought that may be the case, as SBEM has a limit to the amount of surfaces it can handle in a model. Please see below from the iSBEM manual:
There is a way around this in Hevacomp by using Room multipliers - please see here for guidance.
Answer Verified By: Shane Regan
