Window glazing properties, CIBSE Gain
Hi, I am using design database, CIBSE gain to calculate the heat gain in a room. I have a special window setup specifically for this project and all the glazing properties have been inputed in the glazing data section. The problem I am having is that when I change the Shading Coefficient and SHGC in the glazing properties section it has no effect on the heat gain in the room?
Parents Reply Children
