Hi,I am building a thermal model for a 5 storey building but there are problems with the floors lining up.The first floor has a wall height of 3.58 (first floor level of 4.79 and second floor level of 8.37)However, when I view the 3D model, there is a gap between the first and second floor.
the walls appear to not be high enough.
even if I change the wall height, it makes no difference.Is there a way of fixing this?
Please use the 'Setup intermediate floors/ceilings' function (located in CAD Input > Roof/floors) to set up the adjacencies between these floors. This will remove all gaps between your floors.
Shane Regan | Principle Building Performance Support Engineer
That will make things a bit more challenging but you may be able to get around this by using the exclude rooms option, as below. I would really need to see the project to give more specific advice however. Could you please exit Hevacomp, zip the project folder and upload using this link?
