when i add a floor to the model, it appears offset instead of directly over on top of the previous floor, could this be an issue with how my DXF files are laid out?
The reason i ask is that the DXF file's show the same offset in plan view, please see attachment for example of the issue.
Helloit looks like your DXF files have been generated from a "view" rather than model space. Bentley Hevacomp ignores any defined view data and uses the raw model space information for alignment.This document provides more details.Regards,Duncan
Duncan Brown
Answer Verified By: FairClough
