I am trying to model my building with some Solar Thermal included. I have run the Part L Calc and on the compliance report down towards the end of the document it has a section for Solar Thermal but it says the actual building and notional building are both 0. I have a separate system for Solar Thermal to the default HWS and have applied it to the corresponding Zones I have created but it is still showing 0 in the actual column. Can anyone please help?
Hi Matt
There are a lot of things to consider when generating an SES system, so I will need to see your project to comment further. If you use this link to get the project to me, I will take a look.regards,
Duncan Brown
Hi Matt - Thanks for the project. I've taken a look at it - when specifying an SES system you should also include storage for your HWS system. If you select that option your SES system will be considered.
Answer Verified By: Stephen Brown
