Incorporating more than one wall type in a section of external wall using DDB
On typical single storey warehouse buildings where blockwork cavity walls are often used for the lower section of external wall, and either single-skin or double-skin metal sheeting is used above the blockwork walls up to the roof line, how can this be modelled using DDB?
Would it be possible to add a sub-surface to an external wall in the same way as a window or door?
Parents Reply Children
